Here is something that is a novelty and has a practical application and can made from the scrap box, the overall dimensions are 400mm *120mm. The indicator shaft is a length of long grain in this case cherry and some sapele end grain. The end grain is about 2.5 mm thick and the long grain 1.5 which tapers of to about 1mm towards the tip (nothing critical). The width of the indicator is 20mm. The sapele is 3 slices off a 100mm wide board, I cut them about 4 mm thick. The 3 pieces of end grain are placed on their edge for about 6 hours in the room you intend to have the device, this is so when completed the indicator will be roughly in the middle. The 3 pieces of end grain are glued to some cherry stock using epoxy (no water based glue) and lightly clamped. When cured the indicator can be machined to the dimensions. The indicator is fixed at the top, I used a brass fitting but anything will do. As the humidity reduces the end grain contracts and bends the indicator one way, and vice versa. It is surprisingly sensitive.
The first pic shows the indicator at a humidity of 30% and the second at 55% (based against my digital hygrometer). I was surprised how quick the indicator responded to changes, there is of course no finish on the indicator.
![3089323026_dcf5fa892b.jpg](https://proxy.imagearchive.com/d26/d26287ef33b0449a2736c9b1bade0bbb.jpg)
![3089324208_9742ef0867.jpg](https://proxy.imagearchive.com/d20/d20ff55a958d3ddbc1efa7b86e75bdb6.jpg)
![3088524735_e7ac65d5b8.jpg](https://proxy.imagearchive.com/79d/79dd1249a905f64d17158ad389c23af1.jpg)
