AlbertoA
Hello, I have always been a little... hesitant to spray for a number of reasons, first of all being the mess of overspraying.
I already own a 3 hp 50 litres compressor, so on the lower part of the accessibility to spraying and a couple of mid priced HVLP guns (if you can consider 43 PSI as low pressure) but my past experiences with this combination were not so good, except that with nitrocellulose varnish, but that is easier than other tasks (mat non gloss). Portability is another issue, moving a 50-60 kgs compressor from inside to outside of the shop where I will be spraying is not easy...
Do you think a turbine system could solve part of my problems. Here in Italy turbines are regarded as a lower quality option, but I think the reason is that the demand is for low priced ones.
If you think they are, my interest was in the Earlex 5000 that I see highly rated entry-mid level in this forum for the 2 stage turbine segment.
Would the step forward (looking at Apollo 1500 for example) a jump in quality of the results? "Rating" is not an issue... a "hobby" rated would be enough for the use I make of it, but for not-so-good results I am already equipped!
Apollo 1500 or Fuji Mini Mite 3X in this 3 stage class?
I will be spraying water based enamels (not primers...), with DIN viscosity around 90 (to be diluted), nitrocellulose for as long as it will be available and possibly dyes and oil finishes if it will be so good that I will use that instead of a brush.
Thanks for your advice.
Alberto
Alberto
