How Unsafe Is it?? Extension leads etc
Mimmo89
19 Mar 2024
Seaview
Good morning everyone,
just wanted to pick your brain.
I'm thinking of building a little "power tools station" in a corner of my garage, hooking several power tools (that would never run at the same time) to an extension lead plugged into the Power Take Off of a small shopvac so that all I have to do is connect the vacuum hose to the tool I'm about to use.
I know the recommendation is to never daisy-chain several extension leads (the PTO of the shopvac would effectively be one) but is it really unsafe? Considering that the hooked tools are all small and with low-power motors - a disc and belt sander, a bench grinder, a pillar drill, a small band saw and a small lathe.
And how unsafe would it be to take it one step further:
- hooking the drill press and the bench grinder to an extension lead
- connect the extension lead to a VFD (I haven't looked at all the ins and outs of this yet or checked if it even is possible with my tools)
- plug the VFD into the extension lead with all the other tools
- connect the extension lead into the PTO of the shopvac?
It'd be extremely useful to have a dial (the same dial) to add variable speed capabilities to the grinder and to control the speed of the drill press without having to change the belts.
Interested to know your thought.
Dom.
I'm definitely not advising, but it sounds pretty safe to me.
That said, I will share an anecdote. I had an office in Manchester some years ago in an old mill with lip service paid to modern electrics, we had a very limited number of sockets available. We ended up running extension leads to power the monitors/computers etc needed for a trio of desks. Come winter, we discovered that lip service had been paid to adequate heating so we bought an oil filled radiator for each desk with was lovely and warm, but of course was plugged into the extension leads. This I think was actually relatively safe as each desk had a different supply. At some point however somebody switched around what powered what. Shortly after we tripped the breaker (thank god) and discovered that we'd managed to link all the oil filled radiators through a single extension lead, which had... melted. Lessons were learned :).
So it's worth keeping in mind that what you're proposing now sounds safe enough (I am no expert), but in the heat of the moment when you need to get something done, things get forgotten and that's when accidents happen.
Absolute no to your ideas about the vfd.
They should be programmed to match the specific motor connected so you would be continually reprogramming it.
The manual of every vfd will tell you that the motor should be hard wired to the vfd as you can potentially damage the drive running it with no motor connected.
And lastly, vfd's are mostly designed to drive a 3 phase motor, with just a few models specifically able to drive a single phase, single capacitor motor. If you have a mix of single and three phase machines you would need at least two drives.
A smarter idea would be to simply get a radio remote control switch to turn the power to your vacuum on and off from wherever you are and power the tools separately and more directly, not through the vac. You can still have your manifold or whatever for swapping the vac between the hoses to your tools.
Remember, if you turn down the speed of a motor using some variable device, you also turn down it's power and make it more likely to stall. This often makes variable speed less useful rhan you might think.
I'd do the first if I thought is saved me much, but I'd shorten as much as possible the extension from vacuum to local multi sockets
I stay far far away from the VFD idea, they have some huge capacitors in them and getting it wrong could be a best expensive, at worst deadly.
F.
Thank you all for your replies and thank you Fitzroy and Sideways for steering me away from the VFD.
Do I sense that plugging the extension lead into the PTO of the vacuum cleaner is safe then, provided I use only one tool at any one time and keep the cord of the extension lead short?
Nothing is 100% safe, within my personal risk tolerance is how I would phrase it. However I ran my whole shed off a 13A 30m extension cable for several years before I finally got proper electrics installed.
I would do it in my shed because:
- It is only me working in my shed, managing the risk of someone switching on a second machine by accident,
- I have an extinguisher to hand in the shed for when I am there, manages risk of an electrical issue in operation.
- I power down the main supply to the shed when I am not there, managing the risk of an electrical issue (fire) when I'm not present.
Risk assessment and management. Your personal tolerance and ability to manage risk may be different.
Fitz
I'm onboard with Fitzroy.
A single extension plugged into the shop vac does carry some risks but nothing that couldn't happen easily enough anywhere.
The main thing to avoid is ever using that extension as a convenient socket to plug in a high power / long run time device like a heater or perhaps a heat gun. Just plug those in somewhere else.
Stick to power tools you are never likely to use at the same time and the risk isn't great.
Avoid using the extension while it is rolled up. The flex really can warm up if you run a hefty current through it while it's coiled. The heat gets trapped between the coils.
Remember that your vac is about 1000-1200 watts so if you have the vac on, then you only have 2kW left to safely draw from the extension cable.
If you turn the vac off, you can load the extension cable upto 3kW.
