How to get it right first time with a dado set.
I've drawn up a table on paper which I keep in the box with the blades
Fit just the two outer blades and do a few test cuts and measure the the average width of the dado cut.
This is the minimum width (obviously) you can cut.
Remember each chipper widens the dado by the thickness of the BODY of the chipper not the width of the tip.
Make a table of all the combination of widths you can cut with blades and chippers.
Then make a second table of the thickness of the shims in combination.
When you want to cut a certain size dado, look for the greatest width in table 1 that is LESS than you want and then add shims from table 2 until you get the width or a fraction wider.
Fit the head and the cut will be right first time. I still do a test cut but there is no fiddling about adding/subtracting shims.
Here is my table - your dimensions will vary
Works for me
MM
