Niall Church
- Joined
- 22 Apr 2023
- Messages
- 238
- Reaction score
- 14
Could be your table,loosen the bolt for the table,sndOther than the blade not being tracked properly, what else can cause a band saw to wander to the right like this? (I know, a table saw would be ideal but I don’t have one.)
It’s Iroko wood so very hard but it’s dry. The one piece I have cut was under a lot of tension and warped straight away when I cut it. That won’t help either.
Could be the table,loosen the bolts underneath and twist the table in same direction as line is 'curving'!Other than the blade not being tracked properly, what else can cause a band saw to wander to the right like this? (I know, a table saw would be ideal but I don’t have one.)
Could be table,loosen bolts underneath and twist or turn table in same direction as line is 'curving'!!Other than the blade not being tracked properly, what else can cause a band saw to wander to the right like this? (I know, a table saw would be ideal but I don’t have one.)
