How to make precision cuts
colinvansmith
New member
18 Dec 2024
Falkirk
Hi all,
I have a project im working on at the moment. I have 300 pieces of wood which measure 10mm x 10mm x250mm. I'm trying to cut these into 10mm x 10mm x10mm cubes but having difficulty making accurate cuts. When I use my electric compound mitre saw, the little pieces ping away once cut and are difficult to find and when I try and do them by hand, it takes a long time and sometimes my cuts aren't straight so it's not a perfect little cube. Can anyone give me some ideas of the best way to cut these into cubes.
Many thanks,
Col
Your question goes in two directions. With the mitre saw, you do not say if the cuts are acceptable, only that the pieces disappear.
Buy one of these:
https://www.amazon.co.uk/DIVCHI-Tier-Greenhouse-Vegetables-Seedlings/dp/B0D8LC6LV9
Cut two holes in the front flap for your arms and the pinging will be confined to a finite area. Count in your head every time you make a cut and then you know how many cubes you need to retrieve.
You do not have to cut all 300 pieces individually. Tape a few together into a bundle. A 5 x 5 square reduces the count to 12 pieces and even without the tent, all 25 cut off pieces are not going to escape.
1) Set up a sacrificial fence at the back, to ensure proper support for the piece
2) zero clearance slot on the base. Alternatively another sacrificial fence - combine the two fences into one L shaped. ( Don't cut all the way though the base of course)
3) Use a stop block for accurate size and repeatable cuts. If you place the block for a longer cut and add a screw in the face towards the cut you can fine tune the stop block position.
Hope that helps.
Another tip when you make small cuts like this DONT lift the blade until it has stopped spinning, small offcut parts get picked up by the blade and flung around if you lift it out.
Hope that helps.
that's a great idea for fine tuning a stop block with a screw, never came across that before
Unless you are really into the idea of problem solving how to make this cut, personally I'd consider buying them in ready made
https://www.amazon.co.uk/s?k=10mm+x...10mm+x+10mm+wooden+cube,aps,98&ref=nb_sb_noss
