Rorton
Thanks, I did look at that one and wonder. What sort of handle do you use, I seen some that are like a cylinder and you can screw the end to put the blade in, or the more normal flat handles
The basic one - I think it’s the number 3. It also makes a good marking knife for dovetails.Thanks, I did look at that one and wonder. What sort of handle do you use, I seen some that are like a cylinder and you can screw the end to put the blade in, or the more normal flat handles
Any one have any tips on how to do a roll to store rings.
I tried with a piece of packing foam rolled up, stuck a few of them down, and then draped over the suede and pushed it into the gaps with a credit card - its a poor attempt, and while im pleased with how ive managed to do the lining, this is letting it down.
bit like this...
My poor attempt...
thanks, I looked at a number of videos on YouTube, but most of them were 'craft' type where people were using fabric in recycled boxes, but the idea was the same, not sure if its more difficult as I have a smaller area. Some seemed to just roll up the fabric, but the suede is so thin it wouldn't have much of a sponging effect...
I used hot glue to secure it - couldn't see copydex doing it in such a small space, perhaps I just need a thin artist brush or something to apply it?
so with your method, your saying that I will in essence fill the whole of my gap with foam, and then cut out the foam to form the 'grooves' so im then left with what would look like 3 pieces of tall thin foam stuck to a board and them cover that with the suede? Then I should have a component that I can then drop into the 2 compartments in the tray?
We have some Ikea PAX wardrobes, and the jewellery inserts in there seem to use square foam - much to the wifes amusement ive removed her stuff and taken some pics. This seem to be a flat piece of foam, folded over/glued together to give the radius
an original U47 from the 1950s, the long body version, it's not my microphone but made for a studio owner in the USA.Which Neumann is going into this? Looks great!
