Thanks Niall y. Took some of your advice. And it worked out a treat. For the base I used a bearing guided rebate bit set at 19mm high so I could use the same thickness wood to fit it.worked out the angles for the top and bottom rim and cut them in the table saw before routing the birdsmouths. Next I want to go bigger with contrasting woods to show off the birdsmouths better. Any suggestions on which wood to use as I’m trying to keep the costs down. I want American black walnut and maple but they aren’t the cheapest and I haven’t got thicknessing capabilities unfortunately.
