https://www.wealdentool.com/acatalog/Online_Catalogue_Arbor_Standard_133.htmlI use the 1/2 inch ones with a couple of different lengths. If I were to buy now, I would probably get the heavy duty ones as they give you a greater diameter but they use a thicker arbor.THey look perfect, I'll see if i can get some for tomorrow. Thanks!
Don't suppose you'd have a link to which arbor you used?
https://www.wealdentool.com/acatalog/Heavy_Duty_64.html
This works really well and I've used it on small boxes. I made a small thicknesser to work with a No4 plane. It adjusts to enable thin pieces to be safely and accurately planed to a precise thickness - quite handy if you have quite a few to make.Of course , it is the glue line that adds strength. You could just use a tenon saw and let in slips of veneer.
Great thank you. That's what i ordered and they arrived today. That is one beautiful box!
Images from our box making course with 1/4 sawn English Oak
That is one very shiny LN Peter! Lovely box mind you...Images from our box making course with 1/4 sawn English Oak, Burr Walnut and African Blackwood splines, finished with shellac and wax. Spaces available in Feb if anyone is interested.
https://www.peterseftonfurnitureschool.com/courses/box-making-course/
View attachment 149519View attachment 149520View attachment 149521View attachment 149522View attachment 149523View attachment 149524
Peter
Looks like a wood river to me?That is one very shiny LN Peter! Lovely box mind you...
Yes you're right, I didn't look at it close enough!Looks like a wood river to me?
I got the long arbor from Wealden that has a total length of 107mm, i think that would give plenty of scope for positioning the splines. The set up worked really well.The only problem with cutting on a router table using a slotting tool and an arbor is that you are limited to the distance in from each end you can cut the spline slots
Its fine if you just want the splines at the top and bottom as per Peters photos but if you have a deeper box and you want them all the way down then I think its the tablesaw or a tracksaw and a jig to hold the track over the corner
Wider splines can be cut on the router table taking passes but I think 3mm is as thin as you can go and there is still a possibility of cutter breakage
