How to construct 3 way joints
pe2dave
2 Oct 2007
Peterborough, Cambs, UK
I'm making a small set of drawers (for cutlery). Using frame and board method.
The frames are 20x12mm oak. The boards are 4mm oak faced ply
I'm looking for a technique to join 3 frame pieces at the corners.
Any suggestions welcome. My brain finds it hard to work in 3D!
hello,
the book you need is called : Fine Woodworking on Boxes, Carcasses and Drawers (ISBN 0 - 918804 - 26 - 4). Mine cost about £10 from Axminster power tool about 3 years ago, I dont know if they still stock it. Hope this helps, regards, Catface.
catface":po7zud0n said:
hello,
Thanks, I'll take a look.
I've experimented using a mitre on the front face with a half lap front to back on the side rails. The joint shows, which makes it a 'feature'! Doesn't look half bad.
Dave
