My method as well but you should wear a glove on the hand holding the chuck as the other scenario is the chuck comes loose in the morse taper and spins with the work.I often do that kind of drilling and when separating them I will always hold the chuck as well as move the tail stock
It didn't look like a face shield, just glasses, safety ones ?I wonder if he was wearing a face shield...
I agree Duncan. There is a lot of movement in the tailstock if it's not locked down. It really is not the way to do it. He is lucky to get away with just a broken drill and dented pride. That lesson will be well and truly locked in.As well as not holding the chuck, he was feeding the drill in by sliding the tailstock, rather than by using the handwheel. If the tailstock is free to slide, it's also free to wobble which may have loosened the arbor.
He also drilled in a long way before withdrawing the tailstock to clear the shavings. The drill can be stuck firmly in such a situation.
I wonder if he was wearing a face shield?
Duncan
And one hand on chuck (1978)I was taught (1964) to stand behind the tailstock.
geoff
