Routermonster
Over the past few months I seem to have acquired a small pile of hand saws (no - I'm not a c*ll*ct*r) ..... and I'm still trying to learn to saw in a straight line.
I bought a Roberts & Lee 12" cross-cut tenon saw earlier in the year, but apart from taking it out of its wrapper from time to time to admire its oiled walnut handle I haven't really used it in anger until a few days ago.
OK, I know I need to practice, but I when I make a cut it seems to be creating a fairly wide kerf, which causes the saw to wobble around, the resulting cut being neither straight nor vertical. I've made some measurements with a feeler gauge and dial calipers, and I've established that the saw blade thickness is approximately 0.75 mm (30 thou), and that the width of the kerf (in a piece of hardwood) is about 1.1 mm (45 thou). Is this too much set?
By way of contrast, I have a couple of old Tyzack 10" cross-cut tenon saws bought off e-bay, and although they do need sharpening (and setting?) they cut much narrower kerfs and stay straight in the cut, even allowing for my ham-fisted technique.
There isn't much set on the old Tyzacks, so when I take the plunge and sharpen them, can I get away with just topping and filing the teeth (provided they don't bind when cutting)?
BTW I've got a couple of dovetail saws. One is a Tyzack which I bought 20 years ago. A few months ago, I topped and filed the teeth in a rip pattern. I didn't bother with re-setting them (too scared to try!), but the saw cuts pretty well now. I was quite pleased with the result of my efforts until I bought a new LN - the performance of which is much better!
Anyway, are there any guidelines for how much set there should be on a 10" or 12" tenon saw?
Thanks for your help
Les
Les
