Hi Guys
I'm new to the forum. So please be gentle.
I'm battling to figure out how much good quality Russian (Baltic) birch plywood sheets should cost and where is the best place to get them. I'm in Andover in Hampshire.
I've done a ton of reading up on the web and it looks like for furniture grade I should be looking at BB/BB grade. With birch making up all the layers of the ply.
The sheet sizes I'm used to working with are 2440 x 1220mm and I use 6mm through to 18mm sheets. But the places I've tried around me have really bad quality ply and I tried ordering from one place on ebay and the ply looked was okay until I cut it up. Lots of voids and the tear out was bad even with taping before cutting and using a 100 tooth crosscut saw blade.
Sorry if any of this sounds like amateur hour but I'm learning as fast as I can.
Any suggestion on where can local some and what it should cost.
