how long?
steve71
14 Aug 2009
ross on wye
How long should oak be left to air dry before it is OK to use?
I used french oak which had been air dried for 5 years (so I was informed by the scirie) to make up a 50mm thick kitchen worktop. I then used all the offcuts to knock up a refectory table for the kitchen.
After about 8 -9 months in situ, the worktop remained stable although where I had 90 degree joins these opened by about a mm.
The table had bread board ends which showed about 3mm either end as the planked sections shrunk.
As a comparison, I have a dining table which is english oak and over 60 years old. I have owned this table for about 15 years and it has been stable thro' that time, that is up to the point I spent 3 years in central france - humidity and temp differences. The bread board ends of this table now show about 5mm, that is only since that time in france.
Is this movement completely inevitable?
steve
As a general rule wood will air dry at about a year-an-inch. The problem though is that outdoors the wood will never dry below ~16% (in the UK) so needs time to acclimatise indoors to reach it's equilibrium moisture content (emc), which will depend on the general temp/humidity in the room it lives in - eg a sealed centrally heated room will require a lower emc (8-10%) than a draughty intermittently-heated room (12-14%)
Brian
If you are going to be ripping the wood into smaller sections for your project, I suggest you do this to rough dimensions after the air drying and during the acclimatisation stage. this will expose new internal surfaces and assist the moisture stabilisation process.
Bob
