I suppose it depends on how many slabs you wish to flatten.
I wouldn't entertain making what you suggest, but rather get a wood supplier that has either a wide sander that will stick it through for you. In fact A lot of places sell slabs this size already converted to show the wood configuration to the buyer.
If I was doing a one off I would seriously look at this method.
However if your going into full blown production runs there are machines out there to handle these sizes.
A lot of posts on YT look ok in the final video, but they never show you the cock ups, time to set up, emptying the chip collector bag, and installing an empty one, rail deflection and especially with a router cutter of max 2 inch diameter the time it will take to reduce the slab to the thickness your looking for.
One person I know who makes kitchen worktops from boards such as this uses a belt sander which has already been suggested.
It also depends what your skill levels are up to?
Is this for internal use in a central heated house?
If so that presents another set of problems with shrinkage and expansion.
I'm sorry I can't be more positive.
