blackrodd
JakeS":2t9c6hlb said:blackrodd":2t9c6hlb said:There is a clutch, it dis-engages when the screw is fully tightened and will drive no further.
Ehhh... kind of. There is a clutch, but it doesn't disengage when the screw is "fully tightened" - like all such clutches, it disengages when the torque required to turn the screw further exceeds the threshold the clutch is set to. Which in my experience (I have what is presumably the same Makita 10.8V drill/impact-driver set as the OP) in a lot of softer woods is "never" because the impact driver will happily rip the fibres of the wood to shreds and leave the screw spinning in a ragged round hole and not engaging with anything.
I've found it useful for a very narrow range of tasks, and I bought it expecting to use it to finish boarding the attic, which I'm sure it'll be fine at. On the other hand, when we moved into our current house it had cracked face-plates on almost literally every light-switch and some of the power sockets because the previous owner seemed to be of the understanding that impact drivers were for everything! I've been putting together some quick utility stuff around the house recently (microwave-and-cat-food units in the utility room, removable shelves in the boiler cupboard) out of pine and pocket holes recently, though, and the adjustable clutch on the drill-driver of the pair is really the only option if I want them to stay together.
(I am very happy with the Makita set, though - and it's definitely nice to have the option of the impact driver for those times I do want the screw buried a centimetre into the timber. ;-)
You must have a different impact driver than I have.
When I use my impact, driving screws into hinges, brackets, or similar, mine stops driving when the screw is flush.
Obviously you could "spin" the screws if you hold it there long enough, should you choose to do so.
Granted, in timber fixing, it will drive screws in as deep as the bit is long and bury them.
Regards rodders
