How are you supposed to remove these screws?
The blade was loose and I managed to remove one screw with time. It would seem neither screw has a serrated shank so both just turn in the hole.
I would prefer not to have to glue something onto the nut side as I think it will be difficult to clean the image up afterwards.
How were they supposed to be removed or tightened without serrations on the shank?
View attachment 118542View attachment 118543
Try using a long file [serrated face] alongside and covering the HEAD of the screw, and putting them into a vise, so that the nut is not covered. Clamp up tight. Then use a [split-nut] screwdriver to turn the nut out – whilst the file face holds the screw from turning.
