Woodwork Journey Dean
With all due respect,.....The whole of the inside of that motor looks like it could do with a good clean, and while you're at it, you can check to see if all the connections are okay.
Did you find the terminal code markings on the terminal board...? Check to see if your connections are the same as I posted up in my pictures......
It’s definitely a bit on the rough side! I found this….
But you can barely read it - that’s after editing the pic. You can’t see anything really with the naked eye
