SkinnyB
Though id share my recent build of my portable air filter for use in my workshop and in the house when sanding etc.
Made from Mdf, it features two 12" 80 watt car radiator fans (£15 each eBay).
Two fine 300x500 100mm f8 grade fine filters (£10 each at dust spares)
One 200 watt 12v power supply. (£16)(Ideally id go bigger next time, the fans stall if both turn on at same time.)
Rough total: £75
I have attached two handles for easy portability and rubber corners on each side to protect the floor it stands on.
Single fan mode and double fan mode.
P1690688 by jamie skinner, on Flickr
P1690691 by jamie skinner, on Flickr
P1690696 by jamie skinner, on Flickr
P1690697 by jamie skinner, on Flickr
P1690689 by jamie skinner, on Flickr
Rubber corners allow me to stand it up on its end if needed.
P1690692 by jamie skinner, on Flickr
Laser cut a custom surround and fitted an old vacuum switch and two rocker switches inside.
P1690693 by jamie skinner, on Flickr
Power-supply mounted inside. constant clean air flow helps keep it cool. Just need to shorten and tidy the wires.
P1690694 by jamie skinner, on Flickr
To hold the filters in and secure them I apply silicon to the outside. Let it cure and then when pushed in create a nice tight seal.
P1690695 by jamie skinner, on Flickr
Rough total: £75
