Homemade table saw
Benchwayze":vn72rqrz said:
Benji,
I have an old Triton Mk 3 Work-centre.
It has a saw-table, saw-carrier, router table and router carrier, and all the fences, guards and mitre guides. I even have a VHS video on its use. I think I still have the manual for it too, so you can assemble it. All you would need is a circular saw to fit into it (A 9.25" saw maximum. I used an Elu which you might find pre-used. )
If you can collect you are welcome to it.
Yes brush motors are noisy, but if your neighbours aren't bothered, then wear headset-style ear defenders, and you won't notice the noise either.
Once you set up this saw, you will have an accurate, saw that can be used for spot-on cross-cutting and also as a proper table-saw.
You can also use it as an inverted router table, and an overhead router. You will need to make a castored trolley to put it on, because the scrap-merchants nicked the undercarriage. (Which I admit, was one part of the work-centre that wasn't exactly the dogs parts! )
Just PM if you are interested or not.
HTH
John :)
A fine gesture.
