IanB
I've just bought the same Nilfisk vacuum - I hadn't thought of adding a cyclone but it seems too good an idea not to, thanks for the explanation!
The system only works properly if the drum is sealed. Holes in the lid set up an airflow from drum to hoover taking the dust the wrong way. Drum pressure needs to be lower than atmospheric.so I drilled a few relief holes in the lid. I imagine that the joints to the cyclone aren't 100% airtight either. ... would that be the cause of the problem?
Hi, some photos would help.Inspired by folks comments on here I bought one of the Chinese cyclones, same as those pictured earlier.
Its is connected to a Henry, but the results I have achieved today are pitiful.
I would estimate that a third to a half of the dust is getting past the cyclone and into the vac,
I have a large blue ex chemical drum for a collector. The Henry collapsed that when I first connected it (using my homemade cyclone system copied from youtube last year) so I drilled a few relief holes in the lid. I imagine that the joints to the cyclone aren't 100% airtight either. ... would that be the cause of the problem?
I understand the principle of centrifugal force on which the cyclone works, but I'm not sure what effect sealing all the joints will have...
greater suction resulting in more waste being pulled into the vac, or greater suction resulting in greater centrifugal effect and thus less stuff in the vac.?
Any one got any thoughts?
And yes I do plan to seal the joints, today was just a prelim test.
Hi there. I did almost exactly the same as you and found that what I had believed to be a high-density plastic drum (with a screwed on lid and seal) would be adequate for the purpose.Inspired by folks comments on here I bought one of the Chinese cyclones, same as those pictured earlier.
Could you fit this axminster cyclone? 4" fittingsWould these cyclones work with a 4" hose on either side of them ? I have an old AEG drum extractor that I use to extract from a planer/thicknesser, band saw, table saw and spindle moulder - all using 4" hose. I'm sure adaptors from 4" to 2" are available. I need to keep a cyclone small because of workshop space.
Something not quite right with your system or you haven't explained it properlyHaving read up on the subject and read posts from others who had gone a similar route I made and fitted a simple pressure relief valve in the lid. It did permit some drop in negative pressure in the drum but obviously needs greater capacity through the relief valve (i.e. larger valve orifice or less strong spring - or both) to raise the negative pressure and enable the system to work more effectively.
I would add that fitting the relief valve did NOT reduce the efficacy of the cyclone and the barrel.
Thanks - I'll see how big it is. might do !Could you fit this axminster cyclone? 4" fittings
Your fixes addressed the wrong problem and with 20% bypassing the cyclone collection it is very badly inefficient. Reinforce the drum, eliminate the pressure release valve and with correctly sized hoses you should have almost 100% collection into the bin. Putting in less good extraction (ash extractors) is the wrong answer.Hi there. I did almost exactly the same as you and found that what I had believed to be a high-density plastic drum (with a screwed on lid and seal) would be adequate for the purpose.
Initially I used my elderly ex-Wickes wet and dry vac. It worked well, leaving around 80% of the material collected in the intermediary cyclone/barrel. However, it did collapse the sides of the barrel significantly in the process.
I would add that fitting the relief valve did NOT reduce the efficacy of the cyclone and the barrel. Since this time I have substituted one of the cheapo ash extractors (ex-Aldi or Lidl?) which produces less negative pressure in the line and less barrel distortion.
The trial goes on!
I disagree.@skeetstar you have several problems most have been pointed out but to repeat.
1) your dust receiving bin is not strong enough you have to introduce reenforcement into the sides, you will need several rings.
2) the bin needs to seal completely, your holes in the lid are causing the dust to bypass the bin. You will probably need to reinforce the lid as well as seal it.
3) the small hose into the cyclone is not doing you any favours but if you completely seal and reinforce the bin it can work.
4) the output hose from the cyclone is far too long it should be as short as possible also if possible you should use smooth internal hoses because the ribs are reducing airflow.
5) if you can use a larger input to the cyclone it will be better but the small hose will still work.
a points to remember; the long ribbed output hose reduces efficiency, a long ribbed input hose reduces efficiency, the cyclone reduces efficiency, a small input hose reduces efficiency, a non sealed bin reduces efficiency,
Can it work? Yes absolutely. I have a setup that is somewhat similar in principle. But with shorter ribbed hose and the connecting hoses are smooth internally.
