Ian Dalziel
Finally got started the no98………..for those of you who know the plane it’s a 10” smoother. The base is still only a test piece (I actually milled it the wrong way round(doh) I wasn’t sure how accurate the mill was going to be but its fine…….
I am making 6 off as I had to buy 6 blades to make them cheap enough…….i also had to buy full lengths of stainless so it made sense to use it…….I am also doing 2 with stainless soles and brass sides.
I now have all the programs written and the stainless cut to size so hopefully just workshop time left.
Stainless is not the easiest stuff in world to machine but I got there and have the settings and I have only used one cutter so far so I must be doing it right.
Sadly have to go back to work so updates will be slow
Ian
Ian
![DSCF2281.jpg](https://proxy.imagearchive.com/db1/db1ea2c81fa322840caea78851d18451.jpg)
![DSCF2283.jpg](https://proxy.imagearchive.com/4c7/4c710f4f2a96a3f35a14ad2da9de7e80.jpg)
![DSCF2286.jpg](https://proxy.imagearchive.com/a8c/a8c432016e6084c5654938ca2e4a8b92.jpg)
