Ian Dalziel
Finally got started the no98………..for those of you who know the plane it’s a 10” smoother. The base is still only a test piece (I actually milled it the wrong way round(doh) I wasn’t sure how accurate the mill was going to be but its fine…….
I am making 6 off as I had to buy 6 blades to make them cheap enough…….i also had to buy full lengths of stainless so it made sense to use it…….I am also doing 2 with stainless soles and brass sides.
I now have all the programs written and the stainless cut to size so hopefully just workshop time left.
Stainless is not the easiest stuff in world to machine but I got there and have the settings and I have only used one cutter so far so I must be doing it right.
Sadly have to go back to work so updates will be slow
Ian
Ian
