I have just acquired an old Sedgewick Morticer that comes with a small collection of chisels (max 1/2 inch). I would like to get a 16mm for hardwood and a 25mm for softwood. Can anyone recommend where I can purchase good-quality sets?
You will need a system to sharpen the chisels
I have a japanese one only used for one job.I have just acquired an old Sedgewick Morticer that comes with a small collection of chisels (max 1/2 inch). I would like to get a 16mm for hardwood and a 25mm for softwood. Can anyone recommend where I can purchase good-quality sets?
16 mmI have a japanese one only used for one job.
Clive.
The user guide I looked at stated the machine would handle up to 25mm in softwood, but I will follow the advice of doing a couple of passes with a smaller chisel as it sounds like awfully hard work using the large chisel. I will also be investing in a cross grain chain morticer for large outdoor projects in the summer so the need for the larger chisel will become moot at that point.You will need a system to sharpen the chisels, Clifton used to make them, there were 3 sets (looks like a counter sink with a variety of inserts to guide the cutter into the chisel) to cover the entire range of chisel sizes. They are rare to find, usually hideously expensive and often as not need sharpening before use. Clifton did a sets for both English and Japanese chisels. The ‘countersink’ had I believe a different angle)
I’d look for any of the old brand of chisels on eBay. They were all good quality, multi lifetime buys.
The Sedgwick mortice is rated up to 3/4” not 1”. I’m not sure why you need 1”? I would use two mortice side by side of say 1/2” thickness to achieve the 1” desired thickness. This was common practice as stock became increasing thick until you get to structural oak beams for instance. Commonly for anything over 3/4” you would use a chain mortice.
PM with the details please16 mm
I've had a Sedgwick chisel mortiser for more than 40 years with English and Japanese pattern chisels.I buy Nakahashi Seisakusho directly from Amazon Japan. Very good chisels and much more economical for me here in Italy.
It shouldn't be this hard surely with this quality of machine.I've had a Sedgwick chisel mortiser for more than 40 years with English and Japanese pattern chisels.
Sharpened or otherwise I have never managed to cut mortises as do those on Youtube who seem to be able to obtain wood akin to butter in consistency.
I guess it should not be surprised at the difficulty I experience in plunging chisels into hardwood as the force required is considerable. On the initial plunge, it's the equivalent of trying to push x4 chisels at the same time verically into the wood. Without a hammer, hard enough getting just one in. OK, when I feel in the mood, I relieve most of the mortise waste with a drill or Domino, but I still wonder at the Youtubers seeming ease of work without this first step.
Or maybe I should try taking my feet off the ground when pulling on the handle?
I now lean towards the Domino and/or slot mortice cutters in an Arboga mill/drill. And depending on my mood, round over the tenons or square off the mortices with the Sedgwick.
