Wend
Hi folks,
My bandsaw insert is starting to look a little chewed up, so I though I ought to do something about it before it's too late. And as I sometimes have small pieces fall down the gap, I thought I would try to make something closer to a zero clearance insert.
I planed some 6mm ply down to 4.8mm, and cut/sanded it into a rough circle - pleasantly surprised by how well both operations turned out! I also made some smaller circleish pieces of ply to be glued underneath, to strengthen the insert. I don't know how important that is, but there didn't seem to be any harm in doing it. All in all it's been a simpler project than I feared it might be, although I haven't actually tried to cut a slot in the right place yet, let alone see if they actually work!
What I'm not sure about is the holes in the original insert, though. It seems to me that these can't be essential: For some cuts they are all covered by the piece of wood for most of the cut. And they'll weaken my plywood inserts, so all things being equal I'd rather not have them. But I guess their purpose is to help with dust extraction, so maybe I should put some in the insert I normally use? And perhaps I could leave them off an insert that I use when I'll be making small bits of off-cuts?
Thanks for any thoughts,
Wend
Wend
