Mcluma
I'm selling due to ill health and moving house the following combination:
Hitachi C12RSH 305mm Mitra saw
Bosch GTA2500W gravity stand
Both in excellent condition - only used for hobby work - not used by builders!
Price £400
The Hitachi C12RSH 240V 1520W 305mm Slide Compound Mitre Saw is ideal for professional carpenters, joiners and kitchen fitters. A highly versatile product, it will allow you to make smooth, clean mitre and bevel cuts both left and right, with ease. You will be able to make mitre cuts to up to 52° and bevel cuts up to 45° and the positive stops are thumb actuated to make switching between angles easy. This ensures that no matter the cut line you need you will be able to achieve it. The powerful 1520W motor drives the 305mm saw to make short work of hard, thick wooden workpieces.
Its large 630mm base provides good stability and the laser marker highlights the cut line for increased accuracy.
Product Highlights:
Input Power - 1520 Watt
No Load Speed - 4000/min
Blade Diameter – 305mm
Dimensions (L x W x H) – 655 x 890 x 724mm
Cross Cut – 105 x 312mm
Bevel Left 45° - 68 x 312mm
Bevel Right 45° - 43 x 312m
Weight - 27kg
1 x Dust bag
AND
Collection only
Or can deliver locally at a small extra fee - location is WOKING
Price £400
Product Highlights:
Laser Guide for Accuracy
Dust Guard
Powerful & Reliable 1520W Motor
Features and Benefits:
- Adjustable laser marker for fast and precise cutting
- Powerful 1520W motor for quick and efficient working
- Pivoting sub fence
- Mitre cuts up to 52° right and left
- Bevel cuts up to 45°
- Compound cuts up to 45 °
- Thumb actuated positive stops for easy angle setting
- Dust guard for improved dust collection
- Large 630mm base for greater stability
- Fine adjustment of mitre and bevel angles
Technical Specification:
Voltage - 240VInput Power - 1520 Watt
Weight - 27kg
Supplied With:
1 x TCT Saw Blade1 x Dust bag
AND
BOSCH GTA2500W PROFESSIONAL MITRE SAW STAND WITH GRAVITY RISE
The Bosch GTA2500W Professional Mitre Saw Stand with Gravity-Rise is a well-designed stand solving many problems combining, transport without the need for liftingCollection only
