hinges
When you say quality? Do you mean cosmetic appearance or strength and durability. If the later I use these for heavy duty gates with suitable stainless steel bolts and washers..
Cranked or straight depending on the gate being flush or inset to the frame ..
Kirkpatrick are a good make, available form several places but I have found Marches Ironmongery to be particularly helpful in the past.
Thanks to you all for your replies, at the moment still looking as I find the galv type are to loose on the pins.
Thanks.
Clive.
