Well I am gob smacked..
Before I joined the latest thing I was searching for which landed me back here again was a Wealdon twin bearing trimmer bit with replacable blades, which I immediately ran over to the Wealdon webby and bought along with a 10 pack of blades. When I came back to the UKWorkshop for another lurk around I came across a post about the Mathias Pantorouter..
Well I think you would have to be insane to not be impressed with the creativity Mathias has, nothing short of a genius IMO.
Well, I thought to myself one day I am going to make one of those come hell or high water, maybe a touch ambitious just yet seeing as I have been doing joinery for about 20 minutes, but one day.
So over on a completely non cutter related board, it is actually a support forum for the Cougar and Silver Bullet digital cutters/ plotters which I have and I am administrator of the forum and pretty much a voluntary support assistant for the lady who sells the cutters, I have been posting about the cat wheel project - really just because I use the cutter to plot out full scale drawings to cut patterns/ jigs etc. Well I had to post a link to the video of the pantorouter and say what a fantastic idea it is, blah blah, one day I will buy the plans and make one, blah blah..
That was yesterday, this morning before heading up to the workshop I checked the forum for new posts and I had PM. One of the members found the pantorouter website and bought me the plans to make it as a thank you for helping to solve the problems she was having learning how to use the cutter/ plotter when she first got it! How sweet is that
Anyways.. I did manage to turn off the laptop without studying every single image and word in the plans and get myself up to the shop.
Made a quick jig to hold the rim blanks while I trim them to size using the compass setup - The compass is basically two 30 inch bars for the router fence, the adjuster part on the fence has a hole to mount a supplied pin for cutting circles but it would not last being used repeatedly in the same template so I put a 6mm bolt through the centre of the jig and filed the exposed thread down until the fence part just slips over it - perfect.
Put the rim blank on I made the other day and centred it, surprisingly it was only about 1mm out of a perfect circle! But I made the quarters so the blank would have 6mm to trim outside and in just to be safe. So trimmed the rim blank and cut the groove which the running surface will sit in, rounded the sharp edges with a 6mm bearing guided round over bit, Sanded the half laps which were not quite exactly half and had about 0.5mm ridge.
I then dragged out the bit of 12mm ply which I tested the kerf bending on to see how it would fit in the groove, its only 12" wide so the proper article will be 4 inches wider, but it fit like a glove.
Also made a start on the kerf cutting jig, made the sled and started the guide rails but hunger and rain stopped play
It's not anything spectacular I know, but for me it is a thing of beauty, I am really chuffed with it so far :lol:
