HI help with kity 419 blade
meathead":32h17yfg said:
I found this site Probois Machinoutils and they sell riving knifes for kity 419 with a thickness of 2.5 and they also have blades
Reference: DP22 200 30 D which is a 2.8 kerf ( no plate thickness)would this be suitable do u think? the also have 2 little holes next to bore which I don't need would this be a problem?
I suspect that 2.5mm was the standard issue, which you probably have. I do recall it being quite thick. If you have the original blade on, it is probably that 2.8mm kerf, so buying a new one of each is pointless.
