after a fairly long winded conversation and another site visit I finally got the arbour up. Me and a team of 3 other chaps got it up in two days, it was a private estate and working hours are permitted between 7:45 and 4:30, we arrived both days at half 9 so we got on well.
My first problem, and the crux of the entire job, was how to go about setting up the post shoes on the concrete base (that had already been slabbed) so they were absolutely where they needed to be, no tolerance to be wrong here at all, not even slightly.
I decided to cut 4 pieces of softwood exactly 3m long, mark one on the bottom of my 12 posts that had all been drilled out to accept the M25 threaded bar to get the locations of the drillings, I then clamped all 4 together dead flush, and drilled the 4 holes I had marked in the correct positions with an 1” spade but.
Assembling this into a square on site and popping the bar and plates into it gave me a 1 to 1 replica of the building. I assured absolute squareness and set about drilling the concrete
Initial laying of my setting out square, if you look closely you can spot the drillings ready to accept the bar and plates.
Once I was happy we had the correct position and we were square off of the property, I put all the shoes in and drilled them M20 to take M12 threaded bar chemfixed into the holes.
Here’s what that looked like, the concreting was not great, very uneven, and the fact the slabs were already down was a lot less than ideal, very tricky to mark accurately. That aside it went very well, and we had our fixings in place ready to receive the posts.
This was the first time I had put this thing together, so I was keen to see if it all worked out. I decided to make 4 sections consisting of 3 posts (1x corner post and 2x straights) and two trellis panels. This way they were self supporting and easy connectable at the end via the middle ring beam.
You can see how it was going together in this photo above, the arches are fitted here purely for stability at this time of the build.
The aim on day one was to get up to ring beam, and that happened so all was going well.
Working our way around here. Two great chaps here. The one on the right hand side is James, he’s been on about 6 months and was formally a willow weaver, and the chap on the left is Pete who has been a roofer all of his life and fancied something a little easier, he’s not sure if he’s made the right choice
I couldn’t of put this up without these chaps, they worked very hard.
We’re up to ring beam here, all measurements, mortices, tennons and laying out so far has worked out a treat. Time for the roof now.
First thing was to get the coving on, that allowed the plate to be put up with greater stability as we effectively widened the ring beam by double. Lovely. Once that was on the plates went up, checked and rechecked for square, and it was fixed down when i was happy we were playing in the correct ball park.
Here’s the only photo I got of the coving on with the plate ratcheted up tight. The chap at the front is the 3rd member of the team, he’s been on with us for 6 years now and loves the site side of what we do.
With the plate up it’s just a simple jigsaw puzzle to get the rafters in and the battens fixed up (all this I done at the yard so provided it goes up exactly the same it’s a simple case of fit and forget)
Up they go, no hitches really just a slight fiddle to seat some home.
It’s bish bash bosh time now.
Battens fixed.
Getting there now
The arches fitted in really nicely, if you get the templates rite the spindle can do all the work for you. This wasn’t touched at all from the machining stage. No faff.
I brushed over the levelling process with the spin plates for the posts and some other fairly boring details and just want to give you the end results of the build. It’s the first proper start to finish I’ve done on here and the next thing I get to make that isn’t a door or window I’ll give it a go again for those who are interested. I appreciate the feedback and I like to share my work with you folks. I hope you enjoyed it. Here’s the thing done and dusted minus some plugs to flush up and some Sanding and snagging.
