Dalboy
Just take it easy it will come to those that wait as they say. Not much on the turning front for me as been busy making some models.
Hi ChasD, Try something simple like my earlier pieces.
Concentrate on the mating surfaces and don't worry about final dimension constraints, just go with the flow from the tools and what the wood is telling you.
You'll soon develop working methods that suit you.
Then as you refine your designs features like mortice and tenon joints where end grain is involved on thinner sections to add joint strength etc. can be added (These also aid in alignment of sections for glue-up)
Yes Linus; These were cut on the bandsaw but did need a little post cut fettling to ensure the mating surfaces matched..... Can you tell me, have you ever cut the taller segments using a bandsaw rather than chopsaw?
Using your method I can reduce wastage considerably but may I ask, how did you fettle the segments once cut? Sanding, planing?Yes Linus; These were cut on the bandsaw but did need a little post cut fettling to ensure the mating surfaces matched.
They were hand planed, if you really need control then you could make up a shooting board, best to have a go and sort out which method you find gives most consistent results, personally I find any form of hand held sanding to be the most inconsistent and least controllable.Using your method I can reduce wastage considerably but may I ask, how did you fettle the segments once cut? Sanding, planing?
