You can become a Supporting Member or just click here to donate.
I really don't know enough about them to describe them well (part of the reason why I am selling). All I can do is send you some detailed photos with some measurements? Would that work for you? Sorry about this.What size / sweep are these?
Thank you very much. This helped a lot.The information that Fezman is asking for are the gouge sizes which, when talking about carving tools, is expressed as the widths across the tips at the cutting edges and the sweep number, together with the style, straight, bent, Vee-tool etc..... forget the lengths and size of the handle.
Henry Taylor tools are British made and used the Sheffield List system of sweeps and all their dimensions will be in fractions of an inch.
Each sweep size in that list of carving tools has a number and this will usually be stamped on the top of the blade under the ferrule and bolster; this, together with the exact width at the cutting tip, (usually in 1/16ths inch), and style (straight, bent, etc) is all that's needed.
The Vee chisel can be measured across the widest part of the tip and will be either 45 deg or 60 degree angle.
Hope that this helps you both.
