Bean
Hello all
well I have a Kity 419 super saw lousy dust extraction so I have made a mod or two.
Firstly I removed the side panel
I then undid two nut which retained the inner blade guard
I ground off the welds and removed the dust port and one side of the guard
I replaced the section with the studs as it provided a barrier between the belt and the saw blade
I then started to fit the new dust chute and cover
made by a friendly local fabricator.
Nearly at the end now, Covers in place, sealed and bolted down
and it works made a couple of cuts saw body is now largely sealed, dust is not escaping through the other holes in the casing as the extractor creates a negative pressure.
I hope this is useful to other Kity owners who are looking to keep Kity clean
Bean
Bean
