Rugbyjack2005
I have a Scheppach HS105 table saw that I bought secondhand a few months ago. It seemed in good condition and until now has been working well. I used it to cut down a bit of studwork and I ended up braking the saw:
The blade clearly was blunt (it had been fine for the MDF that I have cut a lot recently but as soon as I tried to cut something more substantial, it was tough going). I should have replaced the blade but I didn’t have the spanner and nothing I had was thin enough to work (the guy I bought it off has since sent them to me) but thought it would be fine for 1 piece of studwork. Anyway, I was wrong and it wasn’t. It started smoking a little bit, then very big sparks came from the motor. I presumed that it simply needed new brushes (the old ones were chipped and clearly worn) so I ordered new ones. These came yesterday so I put them in, started it up and it sparked again and then cut out and wouldn’t start. I tried changing the fuse on the plug but no joy there.
Is there another fuse or have I broken the motor and if so, can it be repaired? If not, where would I buy a replacement? I have had a look for replacement motors but haven’t been able to find anything.
Any help would be appreciated.
