I have had a radial arm saw for a while, but have only just got around to getting it set up. I have a slight problem, but am stumped on how to rectify it. I cant remember what the saw was originally used for, but it was predominantly for a single thickness of material. It had various blades that have been sharpened, so it has seen some use, but I seem to remember it being a bit of a sideline operation to another business, rather than core so it shouldnt be worn out. i digress...
With everything on the saw locked, the arm can move slightly on the "piston". This is the silver part on the photograph. The arm of the saw and the piston itself rotate in the pistons sleeve at the bottom. This all moves by a degree or two- i have nothing to measure it with, but at 390mm, it is the difference of a kerf. Any ideas anybody- I guess that it shouldnt move at all. At full height, it doesnt seem to move hardly at all. that is why I mention that it may have been used at a single height for its life.
Any ideas what to look at?
