Hello folks, I am struggling a bit with my angles and would appreciate a little help if possible please.
I am trying to check the angle settings on my mitre saw and have run into a memory blockage. I particularly want to check the 22.5 degree setting.
Can anyone tell me the easiest way to do this please. I do have a digital angle finder that I can use but I'm not sure how accurate it is. I'm not too sure either how to set this device because it can't be set at 22.5 degrees because then it doesn't marry up with the fence and the blade. It would seem that it has to be set at something like 112 degrees but again my brain isn't remembering what i probably knew 70 or so years ago.
Sorry to appear dim but any guidance will be much appreciated. Thank you.
