Hi all, have a problem with a door that i have made, its the first if 5 i have made for a renovation of a listed farm house, it is made from sapele and is 21/4 by 4 1/4 frame with 1 inch T & G boards both sides so weight wise i cannot even lift it. The on site carpenter has hung the first one and although it fits snug on one side and along the bottom at the hinge side, the opposite side has a gap of 10mm at the top corner, the bottom corner touches the rebate ok, i would normally tap in the corner of the frame which i also have made from 3 by 6 inch sapele but this is foamed and rendered in and plastered on the inside, it is an inward opening door by the way, i cannot plane off the lower corner that is touching the frame as the door is up against the weather bar. i cannot plane any of the moulded rebate as this has a aquamat 21 seal fitted. The only thing i would try is to plane the top edge where it is touching about half way along to see if this allows the corner to come in slightly. Due to its size of timber used i don't think laying it down with weights on the corner will help. Anyone got any suggestions please, its a £950 door so i don't want to make it again, thanks
