I've been building my first workbench using only hand tools and posting my progress here ...
https://www.ukworkshop.co.uk/threads/yet-another-english-style-workbench-build.124501/
I'm a complete beginner, but things have gone quite well up until building the face vice. This is my second attempt at it and I don't want to cock another one up! Basically, the mortise and tenon will not hammer flush on one side. It is supposed to be a tight fit because it'll experience quite a bit of racking force, so I don't want to keep taking tiny shavings off until it just slides in and out by hand. I've already tried taking slithers off the tenon that won't go flush but it didn't seem to help. I thought I'd cracked it when I realised the surface where the tenon sits wasn't 100% square. That helped a bit but that is square now and the gap is still there (slightly). I can sort of press it (using a lot of force) so it all goes nice and tight but when I let go it comes out on that side again.
Some images to better explain...
Mortise cut by hand so a bit scruffy inside (I don't have a mortise chisel)
Tenon...
Problem...
It's actually not as much as that now after I worked out the surface was not square (even though I spent ages getting it square yesterday)...
But it is still there. I'd say 0.5mm - 1mm...
(Not the best picture but it is there)
From the front...
(nice and tight)
Do any good folks have any advice on what might be causing it? I've been taking shavings off and it persists. It's still a nice hammer fit but I know I'm a few shavings off making it too loose now. The shoulders are all square - one definitely isn't slightly higher. I've been on it for the past hour and got nowhere. Any help will be greatly appreciated!
Tenon...
Problem...
From the front...
(nice and tight)
