I hope someone can help me.
My wife works from home in a log cabin workshop at the bottom of the garden (She is not a woodworker if that's what you thought).
The workshop is about 40 - 50 metres as the crow flies from the front door where there is a bell push, but the house is in the way.
I have run bell wire to a bell in our hall from the bell push and all works fine. I then ran more bell wire from the first bell down the garden to the workshop. When I use the bell push nothing happens in the workshop but the bell in the hall sounds.
If I bridge the contacts in the workshop the bell works fine.
I am assuming the problem is the length of the wire.
Please don't suggest a wireless kit, wireless boosters or wireless anything or I will throw the computer through the window, tried them all and a considerable cost. They are so intermittent, they don't reliably work in the hall.
So, I think I need some sort of relay in the workshop that will pick up the signal from the bell push and allow me to amplify it to trigger the bell.
Can you help? What sort of relay should I get, there are loads at Maplins but I just don't know enough to know which I need, or, is there another solution?
Just a thought, they are just cheap, battery operated bells from Wickes, using four AA batteries in each so about 6v. Would I be better getting a transformer operated one?
Thanks in anticipation
Mick
Mick
