Froggy
Hi A friend has a problem with the flooring pictured. Big gaps have appeared and the boards were glued down. Any idea what to do about this please?
You say the floor has been glued down. If that is the case the installation is incorrect. The "boards" should be glued to each other and float on the existing floor usually with a combination thin foam underlay/dpc material.Hi A friend has a problem with the flooring pictured. Big gaps have appeared and the boards were glued down. Any idea what to do about this please?
There are two schools of thought on engineered wood floor fitting - the people that fitted ours said : Concrete floor then glue it down, timber floor then float it on an underlay with glued joints.You say the floor has been glued down. If that is the case the installation is incorrect. The "boards" should be glued to each other and float on the existing floor usually with a combination thin foam underlay/dpc material.
To me it looks like the floor has simply dried out after installation,as I suspect as others have suggested it was not stored correctly prior to installation.
When I zoom in on the first photo I can see what looks like the correct foam chip underlay through the gap between boards. That being the case the floor has not been glued down. The opening up of gaps between the boards also means they have not been glue together.
I would get the skirting boards or edge trim off and see if you can lift the boards without damage. If so you may well be able to relay it, gluing the board edges as you go along.
Colin
