tulogngham
StillJustAboutGotAllMyFingers
- Joined
- 22 Feb 2011
- Messages
- 43
- Reaction score
- 4
Folks,
I need some advice. I brought a second hand table saw recently (iTech 315) and on bring it home and installing, I found the old switch was a bit temperamental.
Temperamental in terms of (1) If I bang the table, the motor switches on, 2) The green NVR switch sometime works, sometime doesn't work.
So I though that I would replace the switch but also add in an emergency stop bottom.
On opening up the old switch I found it pretty much EXACTLY the same as the new switch. So I've wired it as follows: See wiring diagrams.
Now on the new switch, when I press the button the saw turns on but if I release the button, the saw turns off !
Here are the wiring Ive done.
Q1. Could someone tell me what that small black wire is going to the motor ?
Q2. Is my wiring correct ? Sanity check please.
Q3. Have I got the right part in the first place ?
Tu
Tu
