You won't be disappointed with the 9404 I've had mine for 15 years and used it on various projects. It's still going strong.
Hold tight onto the thing when you fire it up. My wife attempted to sand a bit of floor with mine. It took her for a ride!
A number of years ago i was in my bosses joinery shop and we had to buzz down some timber with a beltsander. He sent me upstairs to use the new makita..... i tried the trigger but nothing, plugged in, switch on etc, so i shouted down to him that it isnt working, so he said theres an isokator at the bottom of the stairs! ( im a site chippy normally )
I went down and turned it on, there was a loud screeching whizzing noise followed by a massive thud and then more whizzing..... id pressed the little button on the side and locked the trigger onhe went mental
So after praising the 9404 I went to use it today. Powered it on - nothing. Took it into the shop and tried it again and it worked. Took it back to the job - nothing. Wiggled the mains wire and it worked so removed the power cover and found the cable clamp was so tight it had worked through the insulation and wires.You won't be disappointed with the 9404 I've had mine for 15 years and used it on various projects. It's still going strong.
No absolutely notAfter 15 years use that doesn't sound too bad...![]()
Which belts do you recommend in 60 & 80?Oh and..... buy some cheap 60 and 80 grit belts for fast stock removal, but buy some abranet belts for 100 grit and above, you wont regret it.
