HELP I need a new desktop PC
Until you can get a display on the screen we have no idea what the fault is.
IMHO it is unlikely to be the refurbished PC as these are normally wiped, a new OS installed then tested before being dispatched .... unless you bought it from a private individual whereby all bets are off.
Sometimes you can tell when a machine has possibly posted by the fan noise. If it ramps up then calms down it may well be ok but because there is no picture you can't tell.
Again, I go back to those adaptors. Until you can get a picture on the screen you don't know if it's a bios setting, a faulty Display Port or a faulty adaptor.
Update, reply from supplier:
"When you press the power button a power cycle runs through the machine this is why it goes off.
Don't press the button again and let the power cycle complete, once completed the machine will turn on as normal.
Also, for the screen display please check if the input source is set correctly to HDMI or Auto selection. The USB stick is for the PC to connect internet wirelessly."
Not sure how long the "power cycle" is but after 30 minutes I gave up!
My screen is looking for an HDMI by auto selection, the only other possible issues is I am using a wireless keyboard, with a usb dingle, so going to get a wired one and try again, but the power thing seems really strange, it just runs for 20 seconds and goes dark..
Yep, if the monitor isn't displaying the boot screen (HP Logo, Press Esc. to enter BIOS, etc) then there's something missing between the PC and monitor, the motherboard would have to be wrecked to get no BIOS, which is probably unlikely.
The power cycle is usually just a few seconds.
Did you try powering off at the mains, then pressing the PC's power button for a few seconds, then powering the PC back up again? Been awhile but I think that discharges the capacitors, it's worked for me in the past.
The wireless keyboard/dongle shouldn't interfere with the PC booting.
If you haven't tried it, and I realise this is all getting very tiresome now, turn the PC on with the monitor off, give the PC 30 seconds to boot, then turn on the monitor, if still no picture, turn the monitor off again, unplug the DP cable from the PC, and plug back into the 2nd DP input on the PC, then turn the monitor back on. This will 'force' the monitor to look for an input if there is one. you can leave the PC turned on while swapping the cable between DP inputs
I have been swapping things about in the hope it may be a simple problem but the PC doesn't do anything, its been on since my last post, nothing, no blinking lights or a power on symbol on the switch, I reckon its a dead duck.
Google threw this up, never tried it but has to be worth a shot.
If you have a Windows PC and your screen is black or the display isn’t working, the first thing to try is a keyboard shortcut to either wake the device or restart the graphics drivers. Here are two shortcuts to try:
Wake the screen. Press Windows logo key + P or Ctrl + Alt + Del.
Restart the graphics drivers. Press Windows logo key + Ctrl + Shift + B.
I've had issues with that on first boot of a new or 'new' windows system, as I understand it the first thing it needs to detect when booting is a keyboard connection (which is why I asked about the keyboard lights flashing during boot, if they don't it isn't going further). As it can't boot without keyboard, it can't load the drivers for a non-wired keyboard. No expert, may well be wrong, but worth the OP checking.
If the Windows PC can't post/boot it will emit a long beep through the internal speaker to notify you in most cases, but yes, fair point
Would you mind telling us the exact model you purchased?
If @HOJ followed my link, it's this one
https://www.amazon.co.uk/HP-Elitedesk-Desktop-Graphics-Renewed/dp/B08DL69P6T?tag=forumyield-20
You should not be having these issues with a new / refurbed Pc but I gather it was not a full system, just the base unit and you supplied the monitor / keyboard / mouse so the supplier will have tested the base unit and maybe there is some conflict in the BIOS as they will not have it set up for your I/O devices. To resolve these issues you must go through the boot process logically, at this stage the OS is not involved as it has not been loaded and the first step is to get the BIOS screen up. One issue could be the boot sequence, with a new PC you can load via the USB which the supplier might have done and not set the second boot device as the M.2 drive, but this would not prevent the BIOS screen unless there was a USB conflict so have you tried booting without keyboard or mouse or any USB devices as it should still boot to a screen. Next option is to phone the supplier and whilst on the phone get them to talk you through the process so you can give them feedback and sort out the issue.
