Woodbutcher1960
Hi there. I've only just got back into woodworking as a hobby after years of doing other stuff. I noticed yesterday that I was getting some shavings caught between the iron and the chip breaker on my plane. I spent a bit of time making sure that the back of the iron was flat and the mating surface on the chipbreaker. Here's the thing, if I hold the two together and apply even light pressure, they mate perfectly but as soon as I put the screw in and tighten it up, a gap reappears one one side of the join. I'm guessing that either the iron or the chipbreaker is bent in some way but I can't find it using a straight edge. Any ideas on how I might fix this or do I need new iron/chipbreaker? Thanks
