Heavy Duty Grass
Stanleymonkey
15 Jun 2014
South West London
Does anyone have experience of this type of turf? I know it states domestic gardens, but would it be suitable for an area used by around 20 young children each day? Just want to see if anyone has had real life experience of using this grade of turf.
Pro Hardwearing Turf​
Supplied In: approx. 609mm x 1631mm
Uses: Domestic Gardens, Golf Courses, Sporting Venues
Product: Pro Hardwearing Turf
I Have not used this particular turf but the description covers most situations if it’s accurate. Reading any reviews might help but again they are not always accurate. Turf by nature is very hard wearing but if it’s cut very short and subjected to heavy foot traffic followed by heavy rain then it will suffer but given time it will usually recover , my advice is to buy cultivated turf and not meadow turf . Prepare the ground and water it well , allow to dry/ drain and lay turf . Water well and every day . allow it to fully take before subjecting it to heavy traffic -apologies if I’m teaching you to suck eggs but that could be the best turf ever but you could have the worst soil where you plan to lay it .
I think its the winter months where it suffers the most. The ground is also very compacted at the moment. so lots of drainage issues to sort out as well
Compact is good as it won’t sink , ff you can scratch the 1st few inches or add a few ton of good quality graded topsoil it will make it easier to lay . Unless you going to the expense of land drains I would not worry too much the ground - turf is very tough as long as it doesn’t dry out while taking or sit in 6 inches of water for a long period you should be ok - hard bit is keeping the kids off untill is ready
Thanks - there will need to be drainage in one area. but tat's good to no for the rest of it.
Unfortunately Astro / artificial turf needs more drainage than real turf , many people lay it directly on soil , even over real grass but it looks terrible and doesn’t last . It’s also prone to flooding if there is not adequate drainage leaving you with a soft boggy surface .. like most things it can look awesome if correctly installed/ laid ..
