Hi,
I'm new to woodworking this year so still learning a lot as I go.
I bought a vacuum press for veneering - a vacuum pump and vinyl bag rather than a bench press - The Professional AirPress Vacuum Press System
I'd like to build a proper workshop in a year or two but for now I'm doing everything in an uninsulated garage.
I've been using Urea Formaldehyde glue which I know is temperature sensitive. It's been fine over the summer but if it gets below 10 degrees C in the winter, I'm worried it won't cure even if I use the fastest acting hardener. Also, it would be nice to warm it up just so I can mix one batch of glue and use it for both sides of a panel (I'm just doing one side at a time, with breather mesh on top) rather than having to mix up a batch for each side.
I've been thinking about how to heat it. I looked at heater mats but the only ready to go product I could find is on the Airpress website: AirPress
They're expensive and also need a single phase socket. I don't know what amps but I've just got standard 13A sockets and don't really want to get a 16A socket or whatever since it seems like a waste if I do get a proper space in a few years.
I haven't been able to find much info about making DIY heater mats. If it's possible, it's something I could probably do with some practice. I've got very basic electronics knowledge from doing a few Raspberry Pi projects.
I've thought about building a mini kiln, basically just a box using Kingspan/Celotex insulation, and putting the vacuum bag etc inside. My vacuum bag is 2.6 x 1.35m so I guess a bit bigger than that in size, then whatever height.
My question though is if I do that, does anyone know the best way to actually heat it?
I don't need to go too crazy but it would be good to be able to heat it to about 40-50 degrees C. I don't need any hotter because I wouldn't be using it that often.
I've looked at tubular heaters but I'm not sure since they usually seem to be just for preventing freezing and I don't know if I could get them to heat it up to 40-50 degrees.
I've thought about heat lamps and convection heaters but I'm pretty lost because all the info seems to be for heating greenhouses/sheds etc.
Has anyone done anything similar or has any advice?
Thanks!
Tom
Thanks!
Tom
