John15
A very nice bench Bodgers. Congratulations.
John
John
Ha! I love the illustrations in the Tools for Woodworking book. There are a few things in there that I am planning to give a go.AndyT":3s8kj1k2 said:Will you be working your way through the rest of the "How to make Woodwork Tools" booklet?
Trevanion":3s8kj1k2 said:Very nice work Bodgers!
In regard to that snapped bolt on the Vice, have you tried drilling a smalling hole so you could hammer an allen key in to try and loosen it off? You might not have enough space for that though so maybe one of those screw extractors like these: https://www.screwfix.com/p/screw-extractor-set-5-piece might do the job. I think snapping a bolt is one of the worst feelings known to man, perhaps snapping a tap is a little worse.
Sorry this is a bit late as you have finished (well done, looks good!)Bodgers":3h7znsvp said:...
These Record quick release vices are a pain to fit. Dealing with the various fitting points whilst wrestling with the weight of it is not pleasant. I dread to think how bad this would have been with the large 10" record I still have. ...
nabs":20ev3pfu said:lovely job bodgers, it looks very professional. I wish I had thought of painting the legs on mine.
A couple of questions: does the lamp slide along on its little wooden block? Also, is your the quick release working on your vice - the lever is at a very jaunty angle!
Jacob":ffxau8rf said:Sorry this is a bit late as you have finished (well done, looks good!)
But anybody having to fit a Record or similar pattern vice will find it's very much easier if you tip the bench on its back and fit the vice to the (now) horizontal surface of the front.
StraightOffTheArk":5ztbq5iw said:Jacob":5ztbq5iw said:Sorry this is a bit late as you have finished (well done, looks good!)
It seems so obvious when you put it like that, and yet when I fitted my vice...
Oh well, I'll remember for next time!
Ta for the tip
SOTA
