emlclcy
What would you recommend to protect a new hardwood window cill before its installed?
a varnish not paint
thanks
carl
a varnish not paint
thanks
carl
thank you, expensive but will give it a tryMake sure it’s an opaque finish like Sikkens Cetol HLS basecoat and Sikkens Filter 7 Plus topcoat and not a typical exterior varnish as the weather and sunlight will destroy it in no time at all.
seal a new upvc window
this is an outside hardwood window cill with a upvc window frame sat on topWhen you say window cill, is this outside, or do you mean window board, inside?
This is why I ask!
Good advice. I've always used Sadolin products just because that is what the local merchants stocked 25 years ago when I moved in. Sikkens should be just as good or better. Someone on here published their own comparison trial and if I recall both did very well.
It doesn't. Sadolin and Sikkens work and are excellent. Linseed oil paints are like cats. Spawn of Satan.https://www.ukworkshop.co.uk/thread...vs-sikkens-filter-7-plus.108601/#post-1298963
I wonder how this compares to @Jacob 's linseed oil suggestion,
or if that's just for coloured paints?
Tom
..... Someone on here published their own comparison trial and if I recall both did very well.
Sorry, I know this is an old thread. Is there not a risk of it taking on water and swelling? I ask because I’ve got a couple of oak windows to make and was wondering how to finish. I like the idea of nothing as they will be sat in an unfinished oak clad porch. How long would they expect to last unprotected?If it is oak then nothing, it will age lovely.
I would not use Boiled Linseed oil , I did once and after a time the wood turned black .
