Gary,
I'm making a coffee table - details here:
http://www.plansnow.com/coffee.html. I can very much recommend the plan (it's actually more of a step-by-step article, first published in WoodSmith magazine I think). Very detailed, and more or less takes you through it step-by-step.
The only drawback is that the dimensions are in inches so I've had to convert to real money...
In terms of wood, I've probably ordered more than I need, but I'd rather have too much than not enough, and I plan to build some sofa tables to go with the coffee table anyway. Original order was:
Oak American white - 50mm x 100mm x 2.4M - £25.49
Oak American white - 25mm x 100mm x 4.8M - £14.89
Oak American white - 25mm x 125mm x 7.2M - £26.81
Delivery was quite steep though - £23 for that lot. As per my last post, SL are sending more than that, but I don't know how much yet (doesn't arrive till Monday).
This is also my first venture into hardwood, and in particular buying sawn stock
. My only worry is that I'll have not allowed enough on the thickness of some of the stock - but I'll soon find out.
I arrived at the cutting list using a great peice of software called CutListPlus (see
http://cutlistplus.com/). The plan has a cutting list included, but it's all in inches. Using CutListPlus I could enter all the dimensions of the parts in inches and it converts automatically to mm, and generates a cutting list for you based on metric sized stock. That little feature alone is worth the price of the software IMO (which is about £35).
The only drawbacks with the S/W are:
(1) It can't define cutting lists for sawn boards - only for prepared (planed) lumber - but you can get round this by entering the sawn boards as if they were prepared lumber and making extra allowances (which is also configurable in the software).
(2) It only works in 2 dimensions - that is, when working out the cutting list it doesn't allow for any re-sawing that you might do with thicker stock. But again, you can get round that by just entering individual re-sawn peices as "stock".
As a result I've probably got much more wood than I need, but I don't mind that. Given the delivery charges, I think it pays to get more than you need anyway...
Incidentally (for anyone thinking of building this) - I'm getting the glass from a local glass company in Guildford. They've quoted about £60+VAT, but that's custom made to my dimensions, bevelled and made from re-inforced glass for safety.
regards,
Martin
