Whilst searching forum for info on TCT regrinding service, came across old thread about lack of handsaw doctors, and difficulty of reshaping teeth with a hand file. My efforts in this direction have been much aided by this tip-
Use another blade of desired tpi as a template; HSS hacksaw blades, or impulse hardened blade or bandsaw blade are good as not readily cut by file, and old ones will do if scroungeable! Put template blade in vise with saw and hand file saw till it matches the template. The angles may not be exactly as you want, but now you have a set of regular points/valleys to work from.
